I did my conversion using the kit from http://stopyourtrailer.com/
The installation was not too hard although these things are heavy and you do need to be physically capable of handling them.
The only thing I would say about the disc brakes is that there is a noticeable lag between applying the brakes and the brakes activating which can be a little disconcerting. I am using the OEM Ford brake controller and I don't know if using another might work better. I have a Tekonsha which I am considering swapping to but am not sure about whether the OEM needs to be just disconnected or deprogrammed from the truck computer. I haven't been able to find a straight answer to this anywhere.
