Me Again wrote:
The calipers pins seem to need routine service to prevent them from hanging up. Are these Kodak brakes? Search here and on the web from maintenance suggestions. Chris
You beat me to it!
I would flush the system and remove the calipers and lube the slide pins and any mating surfaces with the proper silicone grease.
You also have a setting Heavy or light.
If you are in need of pads NAPA's best semi metallic are the way to go per Kevin at Kodiak. He has good and cheap pads for sale, he says no one wants to pay for quality.
