ford truck guy wrote:
Ron, I have a set of NAPA's best at the house from my last fifth wheel that were purchased as spares....I intend to swap them within the next 2 weeks....
As far as the slide pins.. I stopped using that lube and started using this - clicky
It states - "It is 100% compatible with internal/external Brake rubber and plastic hardware "..
the stuff you show ( the same I used to use ) shows this -
"An environmentally-friendly, green, non-melting, synthetic lubricant. It is formulated to lubricate under the most adverse brake conditions, assuring that critical caliper pins, and sleeves remain lubricated throughout pad life. For metal-to-metal contact only."
that last part made me change... for metal to metal contact only . . . .
Pic was from 2016, I have since changed to your recommendation. Thanks!
Used it when helping a friend change to EBC pads on his 13 RAM DRW.
