Learjet
Jun 05, 2022Explorer
Cummins12V98 wrote:
The problem I have with my Kodiak 8K and Dexter 3.5K is they are both single piston calipers and they wear the outer pad WAYYY faster than the inner. I keep the slide pins properly lubed.
They LOOK impressive. Only negative I see is the hub cap is not threaded to allow for oil bath.
The disc (rotor?) part slides over the lugs, so I guess you could change the hub to one with an oil bath.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
