Cummins12V98
Jun 05, 2022Explorer III
Learjet wrote:Cummins12V98 wrote:
The problem I have with my Kodiak 8K and Dexter 3.5K is they are both single piston calipers and they wear the outer pad WAYYY faster than the inner. I keep the slide pins properly lubed.
They LOOK impressive. Only negative I see is the hub cap is not threaded to allow for oil bath.
The disc (rotor?) part slides over the lugs, so I guess you could change the hub to one with an oil bath.
Separate rotor makes it an even better system as mine are one unit hub and rotor.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
