otrfun
Nov 09, 2016Explorer II
Disc Brakes: 1 Piece Rotor/Hub vs. 2-Piece Rotor & Idler Hub
Giving serious thought about installing disc brakes on our dual axle 5th wheel with 7k (8-bolt) axles. Looks like it costs about the same for a one-piece hub/rotor combination as it does for a separate, 2-piece rotor and idler hub. It would seem maintenance could potentially be less hassle (and cost) with the ability to replace/work-on just the rotor or idler hub in the event either needed work. Any other pros and cons I should be aware of? Thanks!
