Did mine this summer, wasn't too difficult. I used steel lines, eTrailer sells a 66" line that is intended as the crossover line. Used Kodiak disc and Titan pump, that pump is excellent. One trick I realized is that with a pump, bleeding the brakes is a one person task. I just used 20 ft of wire and a switch connected to the breakaway wire and I could control the pump from any wheel position.
