boogie_4wheel
May 13, 2014Explorer
4x4FF wrote:wgriswold wrote:
How would removing the ground cable first negate any sparks?
It has to do with current flow. You will almost never get arcing when disconnecting the ground first even if there is a dead short.
Steve
That doesn't make any sense to me. Arcing is a result of difference in voltage potential and load. If there is an electrical load in the trailer and you pull a battery cable, you will get the same amount of arcing from the pos or neg post. If no electrical devices are on, then no arc (regardless of which is pulled first).
The only reason to pull the neg cable first would be so that the tool(s) used on the clamp/post would not ground the battery if they were to contact the trailer frame. If you were to contact the frame from the positive side AFTER the neg cable is removed, the circuit is open and no arc, making this the safer practice.
About Fifth Wheel Group
