oldtrojan66
Mar 10, 2016Explorer
My '07 JAYCO has the same set up. I use the adjustable chocks that lay on the ground between tires. My tires are also 235/85R16 Goodyears. I tried to buy a Sailun tire with same specs. Diameter of mounted wheel was a full inch larger than Goodyear.
I always thought closer together would mean less twisting flex in tight turns.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
