Super_Dave's avatar
Super_Dave
Explorer II
Jul 08, 2020
Ditching Dometic Thermostat?
Can I swap out my POS Dometic Thermostat with a simple household thermostat?
  • It is digital and I don’t see any model numbers on it anywhere. If it gets bumped at all the cooling and furnace numbers go into the 20’s and won’t go any higher than 32. 50 tries of resnapping the cover on and I might get lucky to get it to recover. Anyone else had this experience?
  • Yes, I did ours a month or so ago. You need one that runs on batteries though. Thermostats in an RV are 12 volts and house thermostats are 24 volts. If it’s battery operated it will work. I used a Lux digital one.
    Here’s how to wire it.
    Red = RH+RC - Power
    Yellow=Y - AC compressor
    White=W - Heat
    Green=G - Fan High
    Blue=No connection
    Gray=No connection - Fan Low
    Not if it is digital.
    Post the model number or a picture.
  • Just changed mine yesterday. Honeywell rth2300/rth221. I got the programmable because it has back light. Don't need to program. you only use 4 wires. Youtube is your friend. $24.00 at HD.Y
