DutchmenSport
Apr 01, 2016Explorer
On my first TT, I used a regulator. On my second TT, I used a regulator for about 4 years and then the second 4 years I did not. On my current TT I am not using a regulator.
BUT!
I am not using a regulator because I fill my fresh water tank at the camp ground and use my on-board water pump. When the fresh water tank gets low, I fill it again.
Why?
Because I do not want blown plumbing inside my camper. Once we pulled into a KOA campground the office persons told us to be sure to use a regulator at the camp site because the water pressure was over 80 psi and most campers are designed for around 40 psi. I had a regulator, but it was one of the small ones you get as a freebie when you purchase a new RV. Really, had no idea how "truly" reliable it was. So I decided to fill my fresh water tank and pump from there. Ever since, I've been doing it that way. The on-board pump is designed to pump only so much pressure, which is in safe tolerance of the camper plumbing. I've never had a problem or a worry doing it this way. There is always adequate water pressure from all my spigots and shower and faucets. And I never have to worry about broken or busted water hoses or water leaks if we are gone. When we leave I almost always just flip the switch to the water pump, and "BINGO"... no water pressure to worry about.
That's how we do it!
BUT!
Why?
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
