Johnny_H wrote:
Ok, I have to ask, why does everyone recommend running LT tires on a trailer instead of ST's when there are major differences in the construction of the tires. See attached excerpt from Tirerack.com
There are differences in the driving requirements between the tires on your trailer and those on the car or light truck you used to tow it. Therefore there are distinct differences between the way trailer tires and tow vehicle tires are engineered.
Your tow vehicle is a leader, which means traction is a key focus in the design of its tires. Traction allows your tow vehicle to accelerate down the road, turn around the corner and brake to a stop. Another important consideration is tow vehicle tires are designed for ride comfort, which is achieved in part by allowing their sidewalls to flex.
Your trailer is a follower, which often makes tire sidewall flexing a negative. Sidewall flexing on trailers, especially those with a high center of gravity (enclosed/travel trailers) or that carry heavy loads, is a primary cause of trailer sway. Typical passenger radial tires with flexible sidewalls can accentuate trailer sway problems. The stiffer sidewalls and higher operating pressures common with Special Trailer (ST) designated tires help reduce trailer sway.
Also consider that Special Trailer (ST), as well as Light Truck (LT) tires are fully rated for trailer applications. This means ST- and LT-sized tires can carry the full weight rating branded on the sidewalls when used on a trailer.
Because this trailer luckily came OEM with LT tires.
Take some time to read this post!
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23225970/srt/pa/pging/1/page/1.cfmAnd you might want to read this one also.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23161726/srt/pa/pging/1/page/1.cfmChris
