mguay
Jun 06, 2013Explorer
Cummins12V98 wrote:mguay wrote:
The one thing that no one hit on was this. If you get yourself into a situation where you would actually need a slider to make "that" sharp of a turn...you are going to need more than a back window! The suspension and tin that holds the 5ers of today will be bent and or broken! Any time that you crank over a dual axle trailer like that it will drag one of them and bend stuff up. I had a slider in a SB and used it one time...I didn't need it and ended up tearing off the tailgate protector when the pin box hit it!
Wow you must be talking about some bottom of the barrel RV.
Keystone!
When I bought mine 4yrs ago I noticed that both equalizers were "leaning" about 1 1/2" out of vertical. I called Keystone and sent pics. They asked if the dealer used a skid steer of fork truck to move the units. Yes don't they all. They told me it happens when they turn them too sharp and drag an axle. They recommended I get the alignment checked. I did and it was still spot on. I have towed it over 20k since with no bad tire wear. This spring I needed to remove the coroplast to access a dump valve and found the beer can crossmember at the equalizer area broken off both frame rails!
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
