Wild_Card
Jun 13, 2018Explorer
Sandia Man wrote:
No doubt due simply to the physics involved a 5er should tow better than a TT, that being said a TT can be towed without the effects of sway when you have enough truck, are properly loaded, and WD/SC hitch is dialed in correctly, there is some trial & error initially.
We have a TT TH that is pretty much the same size and weight and have a very comfortable towing experience whether fully loaded with toys and full water tanks, or without toys and just one water tank full as we always carry water. We travel at interstate/highways speeds without sway.
Our rig has black, gray, and 2 FW tanks ahead of the axles with fuel station and genny tanks to the rear. With toys (up to 3 atvs and dirt bike) we place most of the weight directly over axles, too much behind leads to sway for us. Without toys we place most weight to rear to offset tongue weight.
We keep our ST tires on our rig pretty much loaded up to max psi and our LT rear tires call for max pressure according to door jamb label, both help in keeping her steady. Sure, you could trade for a 5er, but with your truck I would give it a shot and make more tweaks before taking that step.
Just curious what hauler do you have? You also say most weight on axels. How do you get 3 atvs on the axels? My 5th wheel and my TT haulers I only have and had room for 1 ATV on the axels. Your FW tanks are ahead of axels. This helps you tremendously with tounge weight. Alot of rigs FW tanks are on the axels so no help.
Just trying to compare apples to apples.
You can tweak your WD hitch all you want if you dont have enough tounge weight you will sway.
And I do agree with doing what you can before dumping the rig. Exhaust every oportunity. But in the end you have to be comfortable towing and safety.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
