Huntindog
Jun 20, 2020Explorer
dedmiston wrote:
How does it tow without the SxS in it? It would be interesting to test it just to make sure that your problem really is weight distribution.
You should weigh the tongue with and without the SxS loaded, just to verify that your problem is from the low tongue weight.
If that's the case, then you should be able to adjust the height and angle of your hitch to compensate
Wrong.
A WD hich does not or cannot fix low TW! None of them will.
Some how, some way (other than WD) the TW must be fixed.
Proper TW is the cornerstone to achieving a good towing lashup.
Then adding the WD hitch of your choice will make it even better.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
