Duramax1's avatar
Duramax1
Do you jack up your 5th wheel with the landing gear down?
I plan to jack up the 5th wheel in order to lubricate the wheel bearings while the RV is in storage. Normally the hitch is not installed in my truck while the RV is in storage. Is there any problem with jacking up the RV while the landing legs are down? I wonder about taking the weight off of only one of the landing legs and whether this will bend or stress the other leg.
  • Jacking up one axle end at a time enough to get the wheel off isn't going to twist the frame enough to significantly unload the landing gear
  • dbbls wrote:
    I always hitch up when I jack up the 5er. This assures the trailer will not roll and takes the weight off the landing gear. You'll probably be OK if you only jacked one axle up just enough to get the wheel off.
    X 2 BIG TIME!
    Jacking up one side with the landing gear down is going to apply extreme torque to the chassis as the legs will resist the rolling movement you are trying to achieve. I suggest that is NOT a good idea:E
  • I always hitch up when I jack up the 5er. This assures the trailer will not roll and takes the weight off the landing gear. You'll probably be OK if you only jacked one axle up just enough to get the wheel off.
  • When I had someone do my wheel bearings a few years ago he jacked up one side at a time with the landing gears down. I was concerned but he informed me that I had nothing to worry about since he normally leaves the jacks down. To be honest I don't think I would do this in the future. If I wanted wheel bearing (or brake) work done I'd hitch the fiver to the truck first. Common sense tells me you would be putting too much strain on one landing gear otherwise.
    BTW, my fiver incurred no damage at all but I'd still be concerned.
