Rich_Mar's avatar
Rich_Mar
do you really need a battery?
If you only camp in full hookup sites, why do you need a house battery? If the power goes out in the park, we have battery powered lanterns. The only reason I can think of, is to run the frig and maybe the furnace, but the power usually isn't out long enough to affect the frig and we do no cold weather camping. Your tow vehicle provides the power while towing for the running lights. A couple of things that might pop up would be if you needed to roll in the awing or slide. Anything else? What am I not thinking about?
  • You absolutely need a battery! For both the trailer brakes and smoke detectors for starters. Plus the long wire run from the alternator to the house w/o a battery may cause unacceptabe voltage variations etc.
    Why would you not have one?
  • So you're going down the highway and your hitch fails and your 5th wheel detaches from your truck. The breakaway switch tries to engage the trailer's brakes but you took out the battery. Now what?
  • bukhrn's avatar
    bukhrn
    Explorer III
    I'm not getting the reluctance to have a battery.
    Having shore power, doesn't mean you don't need a battery, you still need 12v to run the fridge.
  • Your lights and slide outs are run on 12V power, so is your propane detector and some other things. A good way to test whether you need one or not is to unhook your battery the next time you're at a full hook up park and see what stops working. Then decide if you want to eliminate the battery. My guess is you'll want a battery.
