Aquaholic502
Nov 23, 2011Explorer
my996duc1 wrote:
Couple of questions -
1) I have a cable tv type hook up on the rear driver's side.
The guy who did the walk around with me said it was for if a campsite had cable tv hook up.
I forgot to ask if I need to throw a switch somewhere to go from the cable to the antenna. Anyone know what needs to be done to switch between the two ??
2) Should I re-key the outside "CH751" doors. Anyone know where I can get a bunch of the same keyed locks for all these little doors ??
3) Should I shut the valves off on the gas cylinders when I am not using them ?? Should I shut off the one I am not using or have both on when we are using them ??
_
The switch to go from antenna to cable is behind the tv, kind of hard to get to. I turn on only one tank and when not in use turn all off.
About Fifth Wheel Group
