my996duc1
Nov 28, 2011Explorer
Racorman wrote:
Nice..... have you thought about beefing up the hold downs. I don't know if the stock hold downs are rated for the weight of your Suzuki.
They are rated at 1200lbs each tie down and the Sami weighs about 3000lbs. From what I was told a person can divide the weight over the number of tie downs BUT I wouldn't trust these after crawling underneath and seeing how they are attached. The stock tie downs are just 3 bolts threaded into the frame.... no nuts on the bottom side.
Also the front tires of the Sami end up parked right on top of the front set of tie downs. Figure I will not only upgrade the tie downs I will be using but also add some in the front as well.
About Fifth Wheel Group
