my996duc1
Jan 05, 2012Explorer
danojeno wrote:
It is leaking from a joint where the shower pan, floor, and wall meet, on the far lower left if you are looking at the shower from the outside. According to Eclipse, the water enters from where the shower knobs are, then leaks down and out. It does it every time, so hopefully if you haven't seen it by now, you are in the clear.
I will watch for the leak. Thank you for the heads up. I have only had mine out on one trip and it was just an overnight so shower got used but not much. Next trip to Ocotillo is set for MLK weekend and I will watch for the leak then.
adams92207 wrote:
Do all of you have to plug into the generator plug then run the cord to your twist lock shore power plug on the outside of the trailer? I found it odd that the generator is not wired to power the unit. My friend with a 2011 attitude same model does not have to do this. Was this a cost cutting measure?
I am not following you. I haven't found any twist lock plug on the outside of my mine.
The only thing I have to do, to switch from shore power to generator, is unplug from the shore power and put the cord back into it's storage compartment and plug it back in inside the compartment. It just has a standard rv plug inside there.
Do you have a pic of the twist lock plug and location of where it is on yours ? Just wondering what I should look for and where it is since mine should probably have this, since it is a 2012.
_
About Fifth Wheel Group
