my996duc1
Feb 01, 2012Explorer
stellar714 wrote:
I am doing a second walkthrough on friday any suggestions on what I should be looking for. I caught a couple of things and the trailer was sent back to the factory.
Mine had the following wrong :
- bathroom fan switch didn't work
- converter panel under the fridge buzzed
- fuel staion box (where hose is stored) has hanging loose
- santi-flush hose was stuffed on the tank fitting but hose clamp was loose and hanging at the next low point
- one of the tank bump stops was loose on the frame rail
- water leak around shower faucet
- snap to hold sliding door wasn't attached securely and had worked loose
- leak around window by sink/stove
- tie down bolts (a few) missed the frame and were only into the wood floor
- spare tire lift wasn't the right size for the wrench they included
- screen door plastic slider popped out when it was slid
- hole in the backside of the couch (only visible when folded up)
Some I fixed myself and others I took back to the factory to fix.
Some I found rolling around under the camper on a creeper others were found by taking it out and using it.
About Fifth Wheel Group
