Bakersfield
Feb 22, 2012Explorer
Only issue to check out/consider would be the truck Tonnage (GVWR) that you carry. IF licensed under 10K you are overweight by regulation as scaled. To limit liability -your Truck GVWR should be licensed for 10K (more than your typical loaded weight.
Question: If his truck is only rated to GVWR 9200 lbs, and he is running GVWR 9640 lbs (over 440 lbs), how would licensing the truck for 10K limit liability?
About Fifth Wheel Group
