nayther
Mar 15, 2012Explorer
adams92207 wrote:my996duc1 wrote:
My propane line splits and T's under the propane tank storage.
The one side of the T has a cap on it.
Anyone know what the line with the cap is intended for ??
Anyone replace the cap with a quick disconnect/valve and have a soft line for a grill ??
I've been to Camping World and El Toro RV to look for a setup to replace the cap with a valve/quick disconnect so I can run a soft/rubber line to a grill. Both places have told me this will not work and try to sell me a $80 T with a line that connects up at the tank....
I did see this and intended to tap into it with a quarter turn valve. had one on my previous trailer and it worked fine.
It all depends where the regulator is. If the capped line comes off after the regulator then your BBQ has to be one without a regulator. If your BBQ has a regulator then they're right, you need to T in at the tank, before the regulator. Just about any 1/2" ball valve will work in place of the cap, if you look on a ball valve it should say "125 WOG" that means 125# Water Oil Gas and is the rating of the valve for those services.
About Fifth Wheel Group
