mapguy
Jun 27, 2012Explorer
my996duc1 wrote:mapguy wrote:
The bobbed triangle type center hanger is not special. Found on a lot of lippert/zieman built RV frames that have the adjustable spring location (2 holes). Suprised yours is not reinforced -are the end hangers reinforced -both sides of the U tied togeather with a plate welded between? I will try to get a picture tonight of mine.
Thank you for the info.
Mine is not reinforced, just a big "U" shaped triangle.
Someone else had suggested welding a plate across the legs of the "U".
Any thoughts on the springs being way under-rated when compared to the axle ?
_
Yes, many.
Goes back to this trailer model having a pretty low Factory GVWR. Some component in the trailer assembly, spring, wheel, tire, frame, floor structure and or other unknown factor is causing Eclipse RV to limit the GVWR on that model as manufactured.
About Fifth Wheel Group
