gbeasle
Aug 20, 2012Explorer
I just took delivery 4 weeks ago of Eclipse Attutide FL28AKLG
1) before I even get out of the warehouse I found the tires to have different spacing on either side, so the smallest tire chock will not fit (1 3/4") on entry side. so I did some basic measuring and found 3/4" smaller. I can only assume that the tires do not track straight.
2) 90% of the cabinet door screws are stripped out and cannot be tighten, so I will have to get a larger and/or longer screws and replace them all.
3) the pull out pantry slides fell apart this last weekend 8/18/12
leaving the pull out stuck in the opening.
4) skirt around fuel station needs more support. It was either left off or engineering had a bad day
5) power plug cover will not stay closed, just flaps while going down the road. Duct tape works this time.
6) Generator came from factory unhooked would not turn over then found the positive cable to the solnoid was never hooked up.
7) Second time I dumped tanks Black water valve leaked into space between valve and cap, then I took off cap and surprise. I thought maybe it wasn't shut all the way but this is my third TH and this never happened before.
Can't wait to see what else will fall apart on the third trip.
otherwise we like the floorplan and colors.
So GOOD LUCK
So GOOD LUCK
About Fifth Wheel Group
