my996duc1
Sep 04, 2012Explorer
Racorman wrote:my996duc1 wrote:
How often would you suggest a person to rotate tires and in what pattern do you rotate them ??_
My recollection was that the rear tires got more wear due to scuffing caused when you make your turns. Try to make your turns as wide as possible and that will help some. When I could measure the difference in tire tread, I switched the worse worn tires to the location of the least worn tires.
Next time you make a sharp left hand turn, poke your head out the window and you'll see how much the tires have to flex which causes them to scuff. :E
Thank you for the info.
I will keep an eye on them.
Since the rears are new they will have some catching up to do.
_
About Fifth Wheel Group
