danojeno
Nov 28, 2012Explorer
adams92207 wrote:my996duc1 wrote:danojeno wrote:
Also, I looked for a PSI rating on the wheel and was unable to find one. I have been running 80PSI.
I was looking for the same answer in a post towards the top of this page. I also couldn't find a rating on the rims.
I have never found an answer about the max rim psi rating.
I run about 75psi cold, figuring it will go up abit once warm. I need to check the psi warm to see what they are when warmed up.
_
its funny because my sticker on the side of mine says 65 psi to fill the tires. I have always been under the impression that you want to keep them topped off to prevent blowouts. How many miles do you think were on the tires when they blew?
Yeah, my sticker says the same, but I'm curious why it says that. Probably 3k miles on the tires, but in the tire's defense, I believe it was one of the ones I plugged last spring. I'm looking toward Michelin Rib in LT235/85R16, which is larger in diameter than my current tires, 235/80R16. Only problem is that I don't feel like spending $1,200. Today I am going to measure the distance between the axles and see if they will fit, but I may just throw another cheapo on there and hope for the best for awhile.
About Fifth Wheel Group
