my996duc1
Dec 19, 2012Explorer
Thinking about ways to increase the gray water capacity....
Anyone try adding a twist on valve at the end of the drain pipe and then when the gray tank is nearing full, pull the gray tank valve, then pull the plack tank valve to let the two tanks level out ???
Not sure if a person should then shut both valves again to make sure nothing from the black tank gets over into the gray tank or just leave them both open.
Thoughts about this idea or any other ideas ??
I don't really want to lug around a tote tank at this point.
Here is the twist on valve I was thinking of checking out at Camping World to see if it would work.http://www.campingworld.com/shopping/item/twist-on-valve/27868
About Fifth Wheel Group
