- DtankExplorer
ol Bombero-JC wrote:
Fold-A-Cover, Pullrite SG. Covers it just fine.
Maybe the Q should be...
Does anyone have a cover (brand) that does *NOT* cover their hitch?..:@
....by intent - or accident (bad choice) and maybe wish they didn't have that brand!
Good "should be" for the OPs question......
Maybe I missed it -
but did anyone say their cover did *NOT* cover their hitch?..:h
:W - padredwNomadMine exactly the same as Rob. No interference with the hitch.
RobWNY wrote:
I have a BakFlip F1 folding cover and a B&W 16K hitch. When hooked up, I can keep the tonneau section closest to the window closed so I can keep an eye on things. When not towing, I can close the tonneau fully. There's no contact with the hitch. If I need full access to the bed, the tonneau opens all the way and rests against the back of the truck. I hope this is what you were looking for.
https://bakindustries.com/bakflip-f1 - 2012ColemanExplorer III have the Truxedo lo-pro-soft-roll-up tonneau cover from autoanything.com.
I don't have any clearance issues, and it covers my hitch just fine
- bigorangeExplorer
dennysbabe2 wrote:
While searching for info on Bakflip F1 on a 6 1/2 foot bed I saw your post and I'm wondering about how much room you have between the folded cover and the 5th wheel hitch if you don't fold it up against the window? Wanting to order one but not sure the folded cover will interfere with the hitch.
Not sure the dimensions are same, but I have the Bakflip MX4 on my 2011 Ram with B&W Companion hitch. I haven’t measured, but I have a couple inches clearance between cover and hitch with the cover folded but not against the cab. After I installed it I jack-knifed the trailer with the hitch in towing position and still had plenty of clearance.
Amazon link - dennysbabe2Explorer
https://www.bwtrailerhitches.com/product/patriot-16k
2017 Ram SRW 6'5" bed 6.4 Hemi 3.73's
While searching for info on Bakflip F1 on a 6 1/2 foot bed I saw your post and I'm wondering about how much room you have between the folded cover and the 5th wheel hitch if you don't fold it up against the window? Wanting to order one but not sure the folded cover will interfere with the hitch. bpounds wrote:
....But I think they are all going to clear a cover. Unless you had your hitch head adjusted up above the level of the bed sides, and I don't think any normal setup is going to do that.
Ditto.
Ive never seen a Fifth wheel hitch up higher than the sidewalls of a truck bed.- AnonymousNot applicableYes, Extang Tuff Tonneau III with a Reese 20k hitch. Rolls up with room to spare.
- MikeRPExplorerI have an Advantage Hard Hat. It folds up into 3 sections. No problems!
I have the B&W Companion 20 k slider. - MO_Trout_BumExplorerAccess Lorado over Reese 15k on 2004 2500hd. No problem with clearance over hitch.
- mtofell1ExplorerPretty basic Truxedo roll up and it clears my B/W slider by a couple inches.
About Fifth Wheel Group
