N-Trouble
Mar 18, 2015Explorer
Wow that sucks, sounds like they need to spend a little more time on training their employees how to properly seal a window. New units shouldn't be leaking like this...
So your emergency exit is on the driver side. Mine is on passenger. Go figure...
Mine was also leaking but the only way I knew was because I was getting water leaking down the wall on the inside under the window. Did you not have water present inside? Now I'm still concerned I could have an inner leak and never see it.
I went through to many water leak issues on my last POS WW. You would expect after spending $40k on a new unit that you wouldn't be dealing with this******again...
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
