Allworth
May 20, 2014Explorer II
First check DC voltage at the control boards. It should be above 12 volts and MUST be above 11.4 volts.
Then have an LP technician (since you don't like doing gas work) check the line pressure AT THE APPLIANCES. Not at the regulator. You should have pressure equal to 11 inches of water.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
