rhagfo
Feb 09, 2022Explorer III
ChuckSteed wrote:
If the water pressure is good (you are using a pressure regulator)... not a Camco piece of junk.... then replace the valve
And if you let that foot pedal snap up hard you WILL sooner or later crack the pedal mechanism and be buying a new toilet...
I doubt that replacing the valve will have much effect. I close the valve slowly, but still get a bit of hammer.
The real issue is that there are no built in air chambers in an RVs plumbing. I would suggest, and will likely buy one of these Hammer Arrestor. Simply replace an elbow with a Tee and install the arrestor.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
