routemaster
Feb 10, 2022Explorer
ChuckSteed wrote:
If the water pressure is good (you are using a pressure regulator)... not a Camco piece of junk.... then replace the valve
And if you let that foot pedal snap up hard you WILL sooner or later crack the pedal mechanism and be buying a new toilet...
The pedal did break so I bought a 5/8" rod ABS spun it down to fit in the part glued it in.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
