- ChuckSteedExplorerIf the water pressure is good (you are using a pressure regulator)... not a Camco piece of junk.... then replace the valve
And if you let that foot pedal snap up hard you WILL sooner or later crack the pedal mechanism and be buying a new toilet... - Cummins12V98Explorer IIII know they say to push down and pull foot away to let it snap closed. Try quickly lifting the door pedal instead. I have the same toilet and that is what I do in the middle of the night to make less noise and it still functions fine.
- routemasterExplorerI am bad, it is an Oatey Water Hammer ARRESTER.
- 2oldmanExplorer II
Allworth wrote:
From the post title I think it's the toilet.
Probably "pressure regulator", but more interesting is which valve closes so fast that it causes water hammer?? - routemasterExplorerThe water pressure regulator is good, and the resistors are like one for a washing machine.
- routemasterExplorerThis is the valve.
- AllworthExplorer IIProbably "pressure regulator", but more interesting is which valve closes so fast that it causes water hammer??
- 2oldmanExplorer IIWhat do you mean, resistor? For the pump?
- CA_TravelerExplorer IIIGoogle water hammer.
- Cummins12V98Explorer IIIInstall a small expansion tank.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
