Jerry_BExplorerSep 26, 2013Dometic A/Cs that are bolted down from the top?It appears my A/Cs are lag bolted to the roof. The bolts go thru rubber blocks which I presume seal the bolt hole in the roof. Anyone know how to replace these foam/rubber blocks and what are the tigh...Show More
newman_fulltimeExplorer IISep 26, 2013they bolt from the inside out and are hand tight quarter turn tight do not over compress the gasket
Related ContentDometic 2-Way fridge repair issuesDometic Servel RGE400 fridge too coldWhat load capacity should a ladder have for A/Cs?Furrion A/Cs?Buying a Roadtrek CS - any advice?
