dougrainer
Mar 24, 2022Nomad
heyobie wrote:
What is the purpose of the thermometer? To verify the digital reading displayed above the freezer?
If you have a fever, HOW to you check your body temp? I know my Mom states she can tell with her forehand. :B The Thermometer is used to verify what the temp of the water in the glass is. If a refer is in a slide room, there is NO roof vent, just a outside sidewall door at the top of the wall of the slide room. The 1350 is a large RV refer. It requires a lot of effort to get the hot air running up the back side of the cooling coil to exit out that side mounted door. ALL refers in a slide room need just 1 extra 12 volt fan mounted just inside that door blowing OUT. NOBODY at the OEM level install such a fan. With this fan you will get much better refer cooling and performance. Difference between 40 degrees max to down to 34 degrees. For your testing, remove that upper access door. Doug
The Thermometer does extra duty. You can easily verify the temp output of the roof AC and also how well your Auto dash air is cooling.
About Fifth Wheel Group
