enblethen
Sep 05, 2014Nomad
I would check the distance from the outside wall to the cooling unit tubes. The distance should be less then an inch. I used some good insulating board to reduce the distance. I used Liquid nails to attach it to the frame work of the rig.
Reducing the area makes more air go through the cooling unit increasing efficiency.
If this is in a slide check to make sure the upper air outlet has air deflector to move air away from the void on top of the refer. Make sure the fans are working.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
