Veebyes
Aug 26, 2019Explorer II
As often as possible eyeball what is or is not going on underneath. It is one of those out of sight, out of mind things.
As suggested above, upgrade the shackles & hang on to the old ones just in case. Upgrade to wet bolts & carry a couple spare. We hit one heckuva dip south of Calgary, AB once. Unbeknown to us it sheared a wetbolt. Lucky for us the pieces stayed in place & we did not figure out what had happened till many miles later.
We had spares & the tools needed to do the job. DW & I changed it out in a CG on our own.
As long as you are thinking upgrades, think about the spring packs. Seen one fail in AK. Lucky driver was right next to a CG when it happened. New trailer. Undersprung & overloaded. Inexpensive upgrade. I went from a 6 to a 7 pack. Still managed to break a couple of leaves in those in Newfoundland. The roads are that bad.
Trailer running gear too often is only minimum spec.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
