JenobanditoExplorerFeb 24, 2017Door heightSeven years I had a building built 14" tall so I could get a larger RV at some point. I knew nothing about doors, floors and sidewalls, but I told the large building company what I wanted. Bottom line...Show More
DutchmenSportExplorerFeb 25, 2017Been searching. Here's the first one I found that is under 28 feet with 2 slides, although not perfect from your description, it's a start:Link here.Specs: Cougar half-ton series (Keystone)Specs for 22RBIWEShipping Weight 5820Carrying Capacity 1380Hitch 690Length 26' 11"Height 11' 1"Fresh Water 60Waste Water 38Gray Water 76LPG 60Tire Size ST225/75R15D
Related ContentGarage Door Height ?side door bentDoor Height?Theoretical heights.rear toy garage door clearance height
