laknox
Dec 03, 2021Nomad
Duke-44 wrote:
I'm heading south w/my side by side on trailer behind 30' 5th wheel, I have never done this before. I have to say I am a little nervous. I know there is only straight ahead. Any words of experience from the Knowing?
Thanks
If you have a factory receiver installed, it's likely to be 300 / 3000 lb rated; 300 hitch / 2990 trailer GVW. Most states require trailer brakes on a trailer rated at 3000 GVW and above. Staying under that means no trailer brakes...unless you add them or have a trailer > 3k GVW. At that point, you'd need to add some wiring, a 7-way plug and, maybe, a 2nd brake controller. I've never seen a doubles setup, so I don't know for sure. The reason I say this is that there are LEOs that will ding you for towing an =empty= trailer that's > 3k GVW and you don't have a brake controller installed. I know 2 people this has happened to when towing a car trailer, empty, with a small truck; just moving the trailer from one place to another. Same d-bag cop, both times.
Lyle
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
