- Cummins12V98Explorer III
TXiceman wrote:
Cummins12V98 wrote:
In construction I always referred to feet and inches as it can be confusing. Example if someone says cut to 54" and you are used to 5' 4" that is a bit of a problem.
Bottom line proper communication is where it's at. I am sure Larry will concur!
Actually, it is supposed to written 5'-4".
Ken
I don't know if it's written in stone anywhere but that is the method of communication used within the Commercial Sub Contractors I worked with. - TXicemanExplorer II
Ken - Cummins12V98Explorer III
Lot depends on where in the construction prosses you are, and what tools you have to hand. Many tapes the center of studs is marked better than the feet, and the inches to add to feet is even harder to see.
And doing the grade work, better look close at the plans, often they use feet and tenths.
One job, the state approved plan for driveway & drainage was in ft/tenths, and the plan for layout of slab under garage was in ft/in.
Every bit of site work I did was in tenths of a foot. Wall framing on 16" centers yes I would use the marks but mark 3/4" off along with an "X" to show what side the stud would go Actually I would use an "/" at that takes less time!
Ordering glass and windows for example ALWAYS use feet and inches!!! - JRscoobyExplorer II
One job, the state approved plan for driveway & drainage was in ft/tenths, and the plan for layout of slab under garage was in ft/in. - larry_barnhartExplorer
Proper communication is everything needed for less mistakes and a reason to not have music playing when working.
chevman - Cummins12V98Explorer IIIIn construction I always referred to feet and inches as it can be confusing. Example if someone says cut to 54" and you are used to 5' 4" that is a bit of a problem.
Bottom line proper communication is where it's at. I am sure Larry will concur! - mleekampExplorer
bucky wrote:
A 12 inch trailer? Just put it in the glove box
Reminds me of a documentary about a band that wanted 18 foot tall stonehenge replica for the stage....turns out it was 18 inches. - buckyExplorer IIA 12 inch trailer? Just put it in the glove box
;) - Cummins12V98Explorer III
jdc1 wrote:
Get a huge fuel transfer tank. I can drive over 1,000 miles without stopping pulling my 5th wheel.
Impressive bladder. - jdc1Explorer IIGet a huge fuel transfer tank. I can drive over 1,000 miles without stopping pulling my 5th wheel.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 19, 2026
