johntank
Apr 15, 2017Explorer
joebedford wrote:
I don't think the generator is EFI but there are two lines. It's such a long run to the tank I figured there's a lift pump. If not, how does the prime button work?
There is an anti-siphon valve in the filler neck.
If you have two lines I will say you have a EFI generator, are they the same size for both(?) if not the smaller of the two should be the return. Hope this helps some.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
