powderman426
Apr 12, 2014Explorer
Old-Biscuit wrote:
Found this posting about a problem with a Reese hitch...
I think that while looking and poking at the borrowed 16K I have discovered why these hitches may fail more than other types.
The safety latch is a cheap piece of stamped steel with 5/16" hole to secure a padlock or bar in. What I discovered on this one is that with anything short of a 5/16" bolt pulled up tight I can push the safety up far enough to allow the rod to be pulled out. If the moving part of the safety is bent, even a little bit, which this one was, it gets even easier to unlatch it. Even with a rod or padlock through the safety.
As someone on RV.NET pointed out under this scenario the rod could move out and the trailer unhitch. The springs in the jaws would pull it back in fast enough to relatch and the poor sucker with the now crushed bed or worse would have no idea other than to blame himself for a mistake he didn't make.
Check the engagement of the 'safety latch' and see if yours can be overcome. May have been why your hitch released when ALL looked good
Thanks for the post. I never gave that a thought. I use a Caribbean pin with mine. I may need to rethink that.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
