For the most accurate measurement check both sides of trailer, and take the average. And be sure the tape is plumb when checking
And if the tape says you are close, check the slope of ground before you decide it will fit. If your high point is in front of axles, and behind TV axle, floor inside level, but the ground slopes down towards the building, the TV will be above floor height when high point gets to header.
