Hobo2
Dec 18, 2020Explorer
DRV height
I have a 2016 DRV 38RSSA does anyone know the exact height. Looking a an rv lot with open shed roof but have to get under 13.1 header
JRscooby wrote:Cummins12V98 wrote:JRscooby wrote:
You might get 2-3 inches from tires. But don't want to leave it set with tires that soft.
Might think about building something like the converter used to pull second of a pair of semi trailers. For walking speed/short distance a plate with hole would work for 5th wheel.
Back in until close to hit, allowing for lift as unload TV. Unhook, push dolly under pin, and lower. Hook dolly to bumper hitch, lift legs, back on in. Put weight on legs before unhook.
Newer DRV's have a flat roof.
Looking at the picture, I see things sticking up from the roof.
Most semi trailers have flat roofs, but when hooked to a tractor the front is higher than rear. I bet the same applies to 5th wheels.
