Chuck___'s avatar
Chuck___
DRV window gasket replacement cost
Does anybody know what it would cost to replace the window gaskets or windows on a DRV? It looks like the gasket is pulled away or loose from the window. Some of the windows look a bit foggy. I know windows on houses must be completely replaced -- is this also the case for an RV?
Chuck
  • Dave Root 541-280-3612 La Pine, OR. Check out this blog, scroll down a little and it will talk about going to Dave's.
    http://merika-merika.blogspot.com/
  • foggy windows have been an issue on the DRV fifths. I replaced with help a large window on a MS. He had warranty replace them as they fogged but just sent the window this time and installed your self. So he watched my friend remove and install. Kinda was tough with the gasket on my thumbs. Very common on MH's also.
    chevman
  • Also one in Searcy, AR, rvfogdr.com. And Dave Root RV glass repair in Bend, OR. Positive reviews have been posted on all, including Suncoast Designers, in Hudson, FL
  • There are companies that will remove, reseal and reinstall double pane RV windows. One that I remember right now is in Florida. It's worth a Google search.
    Rusty
