I've read a lot of topics on here about how safe (or not safe) it is to pull a trailer that is close to the max towing capacity of the truck. What I'd like to read here is actual experience (not opini...
taken, im not sure what drw your friend bought but I can tell you my 2016 drw rides worse unloaded than the srw did. Also you mention getting a f450 in your future, why you skipping the 350drw? I bought a f350 drw with the heavy tow capacity which gave me the same wide track front axle as the 450, the gvwr of both are the same 14k lbs, but the 450 s a little heavier giving it less payload. Maybe these numbers will change for 2017 as mine is a 2016.
