I've read a lot of topics on here about how safe (or not safe) it is to pull a trailer that is close to the max towing capacity of the truck. What I'd like to read here is actual experience (not opini...
They add stability and longevity but the OEM Contis are HORRIBLE in the snow. The Toyo M920 is about as aggressive as you can get and still run on the steer axle. More aggressive and you get excessive noise, wandering, and vibration. The Conti HSR that come on the drive and steer axles of a 450 are steer tires so smooth all around to keep the truck from having these issues but in making that compromise, Ford gave up all traction.
