NC_Hauler
Oct 05, 2013Explorer
therink wrote:
My fiver is 37' and 12k lbs. I have never towed with a dually but my 1 ton srw tows my fiver just fine. No stability issues whatsoever.
It is also my daily driver and tow only about 12 short trips per year.
It's hard to know that much about the stability difference unless you've towed the same 5er with both trucks. I have towed the same 5er with both trucks over the same mountainous terrain and the DRW truck offers a more stable towing experience.
If your 5er is only 12,000#, then in reality the SRW truck would be just fine...The dually has it's place and it's "normally" with towing heavier 5er's, but believe you would be surprised in the difference in stability between a SRW and DRW even with your 12,000# 5er.
Mine is also my daily driver..don't particularly care for that, but even if I was only going to tow a couple of times a year, I'd want to make sure I got the right truck for the job...I actually enjoy driving my dually , I guess it's what you get use to...
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
