jaycocamprs wrote:
NC Hauler wrote:
It's hard to know that much about the stability difference unless you've towed the same 5er with both trucks. I have towed the same 5er with both trucks over the same mountainous terrain and the DRW truck offers a more stable towing experience.
If your 5er is only 12,000#, then in reality the SRW truck would be just fine...The dually has it's place and it's "normally" with towing heavier 5er's, but believe you would be surprised in the difference in stability between a SRW and DRW even with your 12,000# 5er.
I towed the same 9000# 5th wheel with a 04 2500HD and with the 05 3500DRW truck we have now. There is a differance even at that weight. If you think that you may ever want a bigger trailer get the DRW truck 1st or get one later. Your $$$, your choice.
I agree with you on that, was just saying the lighter weight 5er's wouldn't require a dually, but even then you would tell a difference in stability if towed with a dually, as your experience showed.
